[GRASS-dev] svn/trac -> git/github migration plan
Markus Neteler
neteler at osgeo.org
Sat May 18 09:10:48 PDT 2019
Hi Panos, all,
On Sat, May 18, 2019 at 5:59 PM Panagiotis Mavrogiorgos
<pmav99 at gmail.com> wrote:
> hello Markus,
> I would suggest that:
> - even core devs fork the main repo
> - "origin" is the personal remote GRASS repository (e.g. in my case https://github.com/pmav99/grass)
> - everyone adds the main GRASS repository as a secondary remote (e.g. "upstream")
yes, it sounds good to me (while my opinion only counts 0.02 cents here).
> This way:
> 1. You always push to "origin" and you create a Pull Request from the Github UI
> 2. To get updates you always pull from "upstream"
> 3. You always rebase your code to "upstream/master".
> 4. You don't need separate instructions for non core-devs.
Updated in a similar way to
https://trac.osgeo.org/grass/wiki/HowToGit#Workflowforcoredevelopers
> Just my 2 cents.
For fetching the updates, is this enough:
git pull --all
Thanks for your recommendations,
Markus
