[GRASS-dev] [GRASS-user] WinGRASS build up (WIP)
Pedro Venâncio pedrongvenancio at gmail.com
Sat Nov 16 11:32:09 PST 2019
Hi Helmut,
gdal-dev was because I was also installing QGIS 3.10. But without QGIS 3.10
and gdal-dev, I get the same gdal300.dll error in GRASS 7.8.1.
The search for curl in c:\windows shows many results (please see images
attached). I start to believe that this can be some local mismatch or
conflict with a past installation of some other software that used curl and
gdal.
Thank you very much for your help!
Best regards,
Pedro
Helmut Kudrnovsky <hellik  web.de> escreveu no dia sábado, 16/11/2019 à(s)
16:45:
> >I'd
> >uninstalled everything related with QGIS, GRASS, GDAL, GMT, etc, >and
> installed again from OSGeo4W.
> >At t
> >he final stages of OSGeo4W installation, I get the same >curl_mime_init
> error with crssync.exe, but referring to gdal301.dll >(image attached).
> Are you installing OSGeo4W stack with the exp/testing tick activated? It
> looks like as you're installing gdal-dev/gdal301.dll according to the
> screenshot.
> Then it could be that some library mixing/mismatch may happen.
> Try to install a fresh OSGeo4W in normal mode only for winGRASS 7.8.1, then
> try to start winGRASS.
> In the windows Explorer, search in c:\windows for curl and report back if
> you find some curl binary there.
> best regards
> Helmut
> Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Dev-f3991897.html
> grass-dev mailing list
> grass-dev  lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/grass-dev
-------------- próxima parte ----------
Um anexo em HTML foi limpo...
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20191116/8570c76d/attachment-0001.html>
Type: image/jpeg
Desc: não disponível
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20191116/8570c76d/attachment-0004.jpg>
Type: image/jpeg
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20191116/8570c76d/attachment-0005.jpg>
Type: image/jpeg
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20191116/8570c76d/attachment-0006.jpg>
Type: image/jpeg
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20191116/8570c76d/attachment-0007.jpg>
