[GRASS-dev] GRASS Docker container - new website ?
Markus Neteler neteler at osgeo.org
Fri Jul 3 07:15:14 PDT 2020
Hi Rainer,
On Fri, Jul 3, 2020 at 10:58 AM Rainer M Krug <Rainer at krugs.de> wrote:
> I just found the docker images, and am happy, that they are there!
> But I am have three questions:
> There is limited info on how they can be used on https://hub.docker.com/r/mundialis/grass-py3-pdal
There is more info here but dockerhub isn't showing it...
> but there is no mention of the GUI (I assume it is not working?)
An attempt with GUI is here:
https://hub.docker.com/r/neteler/docker-alpine-grass-gis-gui
based on  https://github.com/OSGeo/grass/blob/master/docker/alpine/Dockerfile_alpine_wxgui
> or examples on how the image can be used. It would eb useful, if some more info could be provided by somebody who uses / knows these images.
> It would be useful, to include a link to the documentations itself in the new website.
Agreed... it is all due to lack of time but writing documentation
could be done by "anyone".
> The second questions concerns the R integration - it sounds intriguing, to consider that R interfaces with the GRASS docker container. Is this possible? Has somebody tried it?
I haven't but others likely yes.
I'd suggest a multi-stage docker build approach to "blend" the
different images together.
> The third question concerns AddOns - are they installed in the container, or outside?
We do that inside while building it (in this case "actinia" which uses
above docker images as the basis) with a convenient CSV file listing
the addons and their respective repos:
see
https://github.com/mundialis/actinia_core/blob/master/docker/actinia-core/Dockerfile#L73
HTH,
Markus
Markus Neteler, PhD
https://www.mundialis.de - free data with free software
https://grass.osgeo.org
https://courses.neteler.org/blog
