[GRASS-dev] GRASS Docker container - new website ?
Rainer M Krug Rainer at krugs.de
Mon Jul 6 02:04:24 PDT 2020
Thanks Markus for the info.
I have no need for GRASS at the moment, so I likely won’t look into this, but it sounded intriguing. My thought was to run R normal, and have GRASS in a docker container.
Will think about it, when I have time.
Cheers,
Rainer
> On 3 Jul 2020, at 16:15, Markus Neteler <neteler at osgeo.org> wrote:
> Hi Rainer,
> On Fri, Jul 3, 2020 at 10:58 AM Rainer M Krug <Rainer at krugs.de> wrote:
>> I just found the docker images, and am happy, that they are there!
>> But I am have three questions:
>> There is limited info on how they can be used on https://hub.docker.com/r/mundialis/grass-py3-pdal
> There is more info here but dockerhub isn't showing it...
>> but there is no mention of the GUI (I assume it is not working?)
> An attempt with GUI is here:
> https://hub.docker.com/r/neteler/docker-alpine-grass-gis-gui
> based on  https://github.com/OSGeo/grass/blob/master/docker/alpine/Dockerfile_alpine_wxgui
>> or examples on how the image can be used. It would eb useful, if some more info could be provided by somebody who uses / knows these images.
>> It would be useful, to include a link to the documentations itself in the new website.
> Agreed... it is all due to lack of time but writing documentation
> could be done by "anyone".
>> The second questions concerns the R integration - it sounds intriguing, to consider that R interfaces with the GRASS docker container. Is this possible? Has somebody tried it?
> I haven't but others likely yes.
> I'd suggest a multi-stage docker build approach to "blend" the
> different images together.
>> The third question concerns AddOns - are they installed in the container, or outside?
> We do that inside while building it (in this case "actinia" which uses
> above docker images as the basis) with a convenient CSV file listing
> the addons and their respective repos:
> see
> https://github.com/mundialis/actinia_core/blob/master/docker/actinia-core/Dockerfile#L73
> HTH,
> Markus
> Markus Neteler, PhD
> https://www.mundialis.de - free data with free software
> https://grass.osgeo.org
> https://courses.neteler.org/blog
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation Biology, UCT), Dipl. Phys. (Germany)
Orcid ID: 0000-0002-7490-0066
Department of Evolutionary Biology and Environmental Studies
University of Zürich
Office Y34-J-74
Winterthurerstrasse 190
8075 Zürich
Switzerland
Office:	+41 (0)44 635 47 64
Cell:       	+41 (0)78 630 66 57
email:      Rainer.Krug at uzh.ch
		Rainer at krugs.de
Skype:     RMkrug
PGP: 0x0F52F982
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20200706/a45c3885/attachment.html>
