[GRASS-dev] [GRASS GIS] #3815: compression: libzstd should be a default config and a requirement if ZSTD is default compression method
GRASS GIS trac at osgeo.org
Sun Jul 12 19:09:19 PDT 2020
  Reporter:  mlennert     |      Owner:  grass-dev@…
      Type:  defect       |     Status:  new
  Priority:  normal       |  Milestone:  7.6.2
 Component:  Raster       |    Version:  svn-trunk
Resolution:               |   Keywords:  compression zstd zlib
       CPU:  Unspecified  |   Platform:  Unspecified
Comment (by wenzeslaus):
 Problems reported between Oct 31, 2019 and now:
 * [https://lists.osgeo.org/pipermail/grass-dev/2019-December/093800.html
 ZSTD error]
 * [https://lists.osgeo.org/pipermail/grass-dev/2020-May/094351.html ZSTD
 compression error on Windows]
 Generally speaking, changing the default in minor version became challenge
 for users sharing data (locations, packs) with other users
 ([https://lists.osgeo.org/pipermail/grass-dev/2019-December/093802.html
 ...choice of raster compression method...]) since the requirement was
 version 7.6 compiled //with newly introduced ZSTD//. Expected issues
 between major versions, but not minor ones.
 Even more problems were created by compatibility issues between different
 ZSTD versions.
Ticket URL: <https://trac.osgeo.org/grass/ticket/3815#comment:17>
