[GRASS-dev] OSGeo virtual code sprint
Markus Neteler
neteler at osgeo.org
Tue Nov 10 14:29:25 PST 2020
Hi Denis,
On Sat, Nov 7, 2020 at 7:38 PM Denis Ovsienko <denis at ovsienko.info> wrote:
> Hello all.
> I've been working on a geomorphon data processing project for a while
> and would like to have the code completed and published soon, would it
> make sense to do that as a part of the sprint?
Sure, any contribution is welcome!
> The work that still needs to be done is as follows:
> 1. Merge https://github.com/OSGeo/grass/pull/1052
> 2. Open and merge another GRASS pull request with a few more cleanups
> (ready as soon as you are).
> 3. Open and merge another GRASS pull request with a new feature for
> r.geomorphon (will be ready after a bugfix).
> 4. Finalize and publish a small stand-alone data processing tool based
> on the new r.geomorphon feature. It is a niche solution that I have
> developed as an independent contribution to a research project. I am
> not sure if it is useful enough to live under GRASS or OSGeo hood,
> but hopefully it is useful enough in similar research elsewhere.
> Let me know what you think and if you need additional information.
Please join!
Markus
> Denis Ovsienko
> grass-dev mailing list
> grass-dev at lists.osgeo.org
> https://lists.osgeo.org/mailman/listinfo/grass-dev
