[GRASS-dev] [SoC] GSoC 2021 - Parallelization of raster modules for GRASS GIS
Aaron Saw Min Sern aaronsms at u.nus.edu
Sun Jun 20 23:40:34 PDT 2021
Hi everyone,
Week 2 has concluded, and this is my report for this week.
1) What did I get done this week?
r.univar
  *   Address changes for the PR  [1] , e.g. to use a standard option "nprocs" will now be a parameter for users to indicate the number of threads
r.neighbor
  *   Write test cases for parallel execution
  *   Drafted a PR alongside its implementation [2]
r.proj
  *   Write new test cases for the modules [3]
2) What do I plan on doing next week?
I have managed to come up with a way to parallelize output-based modules like r.neighbor. The idea is to make use of a temporary segment file to allow threads to perform random write operations, which is not possible directly on compressed raster format file without using intermediate cache. With this design in mind, I intend to continue to parallelize similar modules next week. Also, there may be ideas in discussion to encapsulate a benchmarking framework possibly under grass.benchmark as this will be used repeatedly in the future to measure performance.
3) Am I blocked on anything?
No, it has been good so far.
Warmest regards,
Aaron
[1] https://github.com/OSGeo/grass/pull/1634<https://github.com/OSGeo/grass/pull/1634/files>
[2] https://github.com/OSGeo/grass/pull/1654
[3] https://github.com/OSGeo/grass/pull/1663
[4] https://github.com/OSGeo/grass/pull/1670
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20210621/eb87943d/attachment.html>
