[GRASS-dev] hacktober, docs
Vaclav Petras wenzeslaus at gmail.com
Thu Oct 6 17:51:53 PDT 2022
On Thu, 6 Oct 2022 at 13:46, Daniel Torres <nobeeakon at gmail.com> wrote:
> Hi guys,
> are we doing anything for hacktober? I see some 2021 issues in the grass
> repo tagged as hacktober,
...and the grass and grass-addons repos are tagged and I'm ready to do some
reviews. I just didn't have any capacity to do the promotion myself and I
don't know how many people here follow Hacktoberfest (you can, after all,
do the proper Octoberfest), but yes, we are active although there was no
announcement.
> but wondering if it would make sense to make some announcement on the site
> (maybe a dialog when landing in the home, or somewhere in the home )
Yes.
> and if there are  non coding (docs and so on) or first issues we could add
> for this (for the grass website or the grass repo).
I did not check the new rules in relation to the website, but non-coding
PRs in grass and grass-addons will count for sure and with the label, we
are set.
> Also, asking again about the docs improvements. Vaclav mentioned some time
> ago he would like to see some work on that side, and on JavaScript checks
> in Super-Liner .
The checks are more straightforward, so a better fit for Hacktoberfest.
Also, having HTML/CSS/JS checks in place is a good basis for changing the
documentation because we can merge with greater confidence.
> As said before, I'm mostly on frontend stuff and happy to help with that
> (although I'd need some guidance as I'm not familiar with the code and so
> on...) or if you think I'd be helpful in other things, let me know.
If you see something which hurts your eyes or feels really clunky, that
might be a place to start (that might be code, CLI, or documentation on
mobile). Someone will likely be able to point you to the right code. ...or
suggest trying something else first :-)
Best,
Vaclav
URL: <http://lists.osgeo.org/pipermail/grass-dev/attachments/20221006/7b40ed5c/attachment.htm>
