[GRASS-dev] Re: [GRASS-PSC] GRASS 7 Migration from CVS to SVN
Paul Kelly paul-grass at stjohnspoint.co.uk
Tue Sep 25 13:22:55 EDT 2007
Hello Martin
On Tue, 25 Sep 2007, Martin Landa wrote:
> Hi all,
> I'm surprised there isn't bigger discussion about this. The migration
> is crucial for the future development of GRASS. It seems that CVS->SVN
> is not bigger problem for the community.
I think it's an important and relatively urgent issue too. Indeed I would
be trying to push ahead and help resolve some of the technicalities of the
move if only I wasn't so busy with non-GRASS work at the present time.
I will say I was concerned at the idea of only moving the CVS HEAD to the
new repository and leaving the other repositories to stagnate on the
Intevation server. As I said I think it is unreasonable to expect
Intevation to continue to support the CVS server if we are only keeping a
few old not-much-used repositories there. IOW, I don't think the proposal
of only moving the CVS HEAD to the OSGeo SVN server is feasible. We should
move everything.
Although, we don't have to move it all at once. Perhaps we could copy the
CVS head into a new repository and use it as the basis of GRASS 7. We
could release 6.3/6.4 from the current CVS server (while concurrently
starting development on 7.x) and move the grass6 and old grass (we could
rename it grass5) repositories and so on at a later (but not too late)
stage. I would like to hope disk space at OSGeo won't be a problem?
Markus indicated there were some problems with the cvs2svn conversion of
the existing repository and I would like to help resolve these before we
move, if only I could get some time. Will try my best but I'm travelling
at the minute and don't have access to my usual machine. Markus said rsync
was available on intevation.de, so we can take an rsync copy of the entire
CVS repository and work from there, i.e. we don't require extra support
from Intevation, only from the OSGeo System Administration committee, to
make the move. That's good. ISTR from the wiki page one specific problem
where a file had been deleted at some stage and then re-created in CVS,
with the result that CVS had two copies of the file - one in the Attic and
one in the working directory, and cvs2svn couldn't handle that situation.
It was suggested on the wiki to simply delete the older version of the
file and then only import the newer one, i.e. losing the "ancient" history
- that's an example of an issue I feel we should resolve (perhaps by
manually merging the Attic and current files before running cvs2svn)
before doing the "big move". (I might have misunderstood this particular
situation though---I only was able to skim briefly over the issues a few
weeks ago).
> I am not quite sure about OSGeo, the future, etc. People Intevation.de
> were offering stable support for many year (big thanks!). BTW, is
> there anyone from Intevation.de who is following this discussion?
Have I understood correctly that we don't need sysadmin support from
Intevation to do the move? I guess it's OK then although it would be nice
to have a comment.
So in summary, just wanted to say that I support the move and if I had
time would even write up a PSC proposal for it. Just a little bit busy.
Paul
More information about the grass-psc mailing list
