[GRASS-PSC] How to modify module folder content in SVN
Moritz Lennert
mlennert at club.worldonline.be
Mon Jun 22 02:58:45 PDT 2015
On 22/06/15 11:21, Eva Stopková wrote:
> Hi Vasek,
> thank you for the advices.
> Great news! This means that both are now easily usable for all users
> without any special effort. Would you like to do the announcement on
> grass-user mailing list? (In case you are not subscribed, I can send
> it for you.)
> Well, I would prefer to wait with announcement until I will update also
> PCL versions (C++). I have done some other changes in the C versions
> (e.g. in C kriging also 2D interpolation is available, in C++ not yet).
> My first idea was to completely replace PCL version, so I did not modify
> them. But then I realized it would be better to save both versions, so
> at first I would like to make them as much identical as possible
> (funcionality, layout). I intend to do this in the coming days.
Any specific reason why you want to maintain two parallel versions ?
What is the advantage of the PCL version ?
Generally, I would suggest to maintain only one version...
Thanks for your work on these two very important modules !
Moritz
More information about the grass-psc
