[STATSGRASS] R & GRASS inicialization.
andres javier garcia garcia andresjavier.garcia at wanadoo.es
Fri Aug 2 09:05:03 EDT 2002
Hi all;
Now it works (needed to run library(GRASS) first).
All the steps in Roger's mail works right.
(Just a comment: I know what a factor is, but not how the map that I've used
as a factor has become a one through the steps followed in Roger's)
Thanks all, and regards
Javier
El Vie 02 Ago 2002 16:31, escribió:
> You need to load the Grass-R library in R.
> Library(GRASS) if I remember well.
> Laurent
> On Fri, 2002-08-02 at 12:21, andres javier garcia garcia wrote:
> > Hi Roger, hi Agustin;
> > Thanks, I'll follow (just now) your advices about the tutorials.
> > Anyway (because; first of all I'm impatient to check that this works in
> > my computer):
> > The gmeta() function in not found by R.
> > I'm installed the GRASS-R interface and it hasn't complained in the
> > compilation. The dir /usr/lib/R/library/GRASS/ has been created with the
> > corresponding library. And I run R from GRASS.
> > Any suggestion?
> > Javier
> > statsgrass mailing list
> > statsgrass at grass.itc.it
> > http://grass.itc.it/mailman/listinfo/statsgrass
More information about the grass-stats mailing list
