[GRASS-stats] multiple grass installations and spgrass6()
Roger Bivand Roger.Bivand at nhh.no
Mon Jan 21 11:56:51 PST 2013
The message is coming from GRASS, almost certainly from v.out.ogr, and
almost certainly because you have multiple versions of GDAL on your system
(or a GDAL component or plugin). I am not able to help with GRASS 7
problems, it is an unstable development version. Can you export the object
to a vector file in GRASS itself, not inside R? Does the same error occur?
Does the error rather (or also, if GDAL is broken) occur on reading a
shapefile into R with readOGR()? You'll have to separate the problems
yourself until you find out which software component is wrongly linked to
GDAL - best to remove all binary installs of GDAL which on Debian/Ubuntu
are notorious for causing trouble, and install GDAL from source, then
re-install GRASS from source, and rgdal from source.
See also:
http://lists.osgeo.org/pipermail/grass-user/2009-July/051737.html
http://lists.osgeo.org/pipermail/grass-stats/2009-January/000897.html
at the ends of the threads. In both cases the GDAL/OGR GRASS plugins were
the culprits, often caused by binary installs of GDAL.
Roger
On Mon, 21 Jan 2013, S. Koukoulas (lists) wrote:
> How can I get around a possible error with multiple grass installations,
> when I use spgrass6?
> (preferably without uninstalling grass!)
> Here a description of the problem:
> when I try to import data  into R (running R within GRASS 7 (revision
> 54609) environment), I get the following error:
>> nomoi=readVECT6("nomoi_okxe")
> Loading required package: rgdal
> rgdal: version: 0.8-4, (SVN revision Unversioned directory)
> Geospatial Data Abstraction Library extensions to R successfully loaded
> Loaded GDAL runtime: GDAL 1.9.2, released 2012/10/08
> Path to GDAL shared files: /usr/share/gdal
> Loaded PROJ.4 runtime: Rel. 4.8.0, 6 March 2012, [PJ_VERSION: 480]
> Path to PROJ.4 shared files: (autodetected)
> ERROR: Incompatible library version for module. You need to rebuild
> GRASS   <--------------------ERROR--------------
>       or untangle multiple installations.
> and then R crashes and I am out of its environment.
> "nomoi_okxe" data can be downloaded from
> http://geodata.gov.gr/geodata/index.php?option=com_sobi2&sobi2Task=sobi2Details&catid=16&sobi2Id=21&Itemid=
> and then choose SHP (EPSG:2100)
> In my PC I have grass6.4.3svn and grass 7 svn (revision  54609) on an
> OpenSuse 12.2 laptop
> My sessionInfo() output:
>> sessionInfo()
> R version 2.15.2 (2012-10-26)
> Platform: i586-suse-linux-gnu (32-bit)
> locale:
> [1] C
> attached base packages:
> [1] stats     graphics  grDevices utils     datasets  methods   base
> other attached packages:
> [1] spgrass6_0.7-14 XML_3.95-0.1    sp_1.0-5
> loaded via a namespace (and not attached):
> [1] Matrix_1.0-9    grid_2.15.2     lattice_0.20-10 mgcv_1.7-22
> [5] nlme_3.1-105
>> execGRASS("g.version")
> GRASS 7.0.svn (2012)
> I have installed spgrass6 using  install.packages("spgrass6",
> repos="http://R-Forge.R-project.org")
> many thanks,
> sotiris
> grass-stats mailing list
> grass-stats at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-stats
Roger Bivand
Department of Economics, NHH Norwegian School of Economics,
Helleveien 30, N-5045 Bergen, Norway.
voice: +47 55 95 93 55; fax +47 55 95 95 43
e-mail: Roger.Bivand at nhh.no
More information about the grass-stats mailing list
