[GRASS-stats] multiple grass installations and spgrass6()
    S. Koukoulas (lists)
    sotkouklistes at gmail.com
    Tue Jan 22 11:06:59 PST 2013
On 01/21/2013 09:56 PM, Roger Bivand wrote:
> The message is coming from GRASS, almost certainly from v.out.ogr, and
> almost certainly because you have multiple versions of GDAL on your
> system (or a GDAL component or plugin). I am not able to help with
> GRASS 7 problems, it is an unstable development version. Can you
> export the object to a vector file in GRASS itself, not inside R?
yes (from R to grass is ok - I followed your example with meuse data
just fine)
> Does the same error occur?
no
> Does the error rather (or also, if GDAL is broken) occur on reading a
> shapefile into R with readOGR()?
no, readOGR() works fine (tried with shapefiles)
> You'll have to separate the problems yourself until you find out which
> software component is wrongly linked to GDAL - best to remove all
> binary installs of GDAL which on Debian/Ubuntu are notorious for
> causing trouble, and install GDAL from source, then re-install GRASS
> from source, and rgdal from source.
> See also:
> http://lists.osgeo.org/pipermail/grass-user/2009-July/051737.html
> http://lists.osgeo.org/pipermail/grass-stats/2009-January/000897.html
> at the ends of the threads. In both cases the GDAL/OGR GRASS plugins
> were the culprits, often caused by binary installs of GDAL.
ok many thanks - I think that I understand the problem now (but I will
not do anything about it for the moment, as I want to be able to work
with grass6.4.3 as well).
I can import my spatial data to R one way or another, I was just hoping
that there would be a way for the grass package to recognise the right
versions without making redundant one version in favor of another.
best wishes,
sotiris
>  Roger
> On Mon, 21 Jan 2013, S. Koukoulas (lists) wrote:
>> How can I get around a possible error with multiple grass installations,
>> when I use spgrass6?
>> (preferably without uninstalling grass!)
>> Here a description of the problem:
>> when I try to import data  into R (running R within GRASS 7 (revision
>> 54609) environment), I get the following error:
>>> nomoi=readVECT6("nomoi_okxe")
>> Loading required package: rgdal
>> rgdal: version: 0.8-4, (SVN revision Unversioned directory)
>> Geospatial Data Abstraction Library extensions to R successfully loaded
>> Loaded GDAL runtime: GDAL 1.9.2, released 2012/10/08
>> Path to GDAL shared files: /usr/share/gdal
>> Loaded PROJ.4 runtime: Rel. 4.8.0, 6 March 2012, [PJ_VERSION: 480]
>> Path to PROJ.4 shared files: (autodetected)
>> ERROR: Incompatible library version for module. You need to rebuild
>> GRASS   <--------------------ERROR--------------
>>       or untangle multiple installations.
>> and then R crashes and I am out of its environment.
>> "nomoi_okxe" data can be downloaded from
>> http://geodata.gov.gr/geodata/index.php?option=com_sobi2&sobi2Task=sobi2Details&catid=16&sobi2Id=21&Itemid=
>> and then choose SHP (EPSG:2100)
>> In my PC I have grass6.4.3svn and grass 7 svn (revision  54609) on an
>> OpenSuse 12.2 laptop
>> My sessionInfo() output:
>>> sessionInfo()
>> R version 2.15.2 (2012-10-26)
>> Platform: i586-suse-linux-gnu (32-bit)
>> locale:
>> [1] C
>> attached base packages:
>> [1] stats     graphics  grDevices utils     datasets  methods   base
>> other attached packages:
>> [1] spgrass6_0.7-14 XML_3.95-0.1    sp_1.0-5
>> loaded via a namespace (and not attached):
>> [1] Matrix_1.0-9    grid_2.15.2     lattice_0.20-10 mgcv_1.7-22
>> [5] nlme_3.1-105
>>> execGRASS("g.version")
>> GRASS 7.0.svn (2012)
>> I have installed spgrass6 using  install.packages("spgrass6",
>> repos="http://R-Forge.R-project.org")
>> many thanks,
>> sotiris
>> grass-stats mailing list
>> grass-stats at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-stats
More information about the grass-stats
