[GRASS translations] Re: Simply Chinese translation
wlx wlx at mygis.org
Tue Mar 8 08:58:55 EST 2005
Hi Markus,
     Sorry for a later reponse.
     We prepaire to start the simple chinese translation now.  Firstly, I
want to download the latest po files,  and  go to
http://freegis.org/cgi-bin/viewcvs.cgi/grass6/locale/po/, but I don't know
which file is the English version, so where can I get the latest English po
files? Secondly, I am planing use poEdit to do the translation as some of us
use the windows operating system, are there any problems with this solution?
Or any other more efficiency solution?
     Best wish,
     Yours sincerely,
Liangxu Wang
> On Thu, Feb 03, 2005 at 12:44:58PM +0800, wlx wrote:
> > Hi List,
> >      I want to translate grass to simply chinese which code
> is gb2312
> > or utf-8. And are there somebody that are doing it?
> Currently we are not aware of anyone translating GRASS into chinese.
> >      How can I start this translation and where are the
> document to do it?
> You may just pick existing files of another language and
> rewrite to Chinese. 'kbabel' for example supports also asian
> encodings.
> Be sure to set the encoding and language first in the 'kbabel'
> settings *after* having loaded an existing .po file.
> Just pick the grasslibs_XX.po and grassmods_XX.po files from here
>  http://freegis.org/cgi-bin/viewcvs.cgi/grass51/locale/po/
> Everybody in the list:
> Please note that regular (even small) submissions are better
> than waiting lots of time. This reduces extra workload of
> re-syncronizing the files with the actual state of GRASS.
> Thanks in advance.
>  Markus
> Markus Neteler     <neteler itc it>       http://mpa.itc.it
> ITC-irst -  Centro per la Ricerca Scientifica e Tecnologica
> MPBA - Predictive Models for Biol. & Environ. Data Analysis
> Via Sommarive, 18        -       38050 Povo (Trento), Italy
More information about the grass-translations mailing list
