[GRASS-translations] incorrect refs?
Maxim Dubinin
sim at gis-lab.info
Sun Aug 3 01:43:44 EDT 2008
MN> It's always possible to merge messages from some version to the
MN> current version. I have written a small script (for me) which calls
MN> msgmerge which does the job.
This is good to hear.
Martin took time to explain me how version control/svn and related
stuff works, which is really interesting, but I still find it quite
confusing. I also suspect, that I'm not the only one (though I'm
probably a representative of Windows wave which is relatively new to
GRASS and generally unaware of svn etc.) who is confused about how
much steps you need to do besides just translating.
I'd suggest it would help having more simple and direct procedure to
people to start participating and not bothering with checking svn and
running into issues with code/po relations. We tried Pootle, which
seems to be a nice alternative, especially for completely new and
finished translations that require some revising. There should be
something else that can be done to make process easier to participate,
I guess.
I know you're great community and always ready to help, so this just a
suggestion and may be you already gave it some thought and I'm all
wrong :)
MN> For translators: please submit often! Only then we avoid to get out of sync.
We will!
Best regards,
Maxim mailto:sim at gis-lab.info
Вы писали 2 августа 2008 г., 17:30:51:
MN> On Sat, Aug 2, 2008 at 9:08 PM, Maxim Dubinin <sim at gis-lab.info> wrote:
>> hmm, now that's scary given how much we've translated.
>> We took source *_ru.po files from here:
>> http://trac.osgeo.org/grass/browser/grass/trunk/locale/po
>> where it says somewhere that the file were updated with the current
>> code.
>> the code I used to link was taken from here
>> http://grass.osgeo.org/grass63/source/grass-6.3.0.tar.gz
>> So, given that significant portion is translated, what should we do?
MN> Indeed, the .po files should be updated from time to time (hi Carlos,
MN> are you still working on this?).
MN> Best,
MN> Markus
More information about the grass-translations
