[GRASS-translations] [Portuguese]- Submission of Portuguese
translation
Milena Nowotarska
do.milenki at gmail.com
Thu Nov 12 05:03:51 EST 2009
2009/11/12 António Rocha <antonio.rocha at deimos.com.pt>:
> Greetings All
>> Correct, also if any of those files is missing for a particular
>> language, it needs to be created by the translation team.
> In this case, for Portuguese language (pt) it's missing the
> grasswxpy_LANG.po.
> Can I request to the translation team creates this file and send it to me?
> (What I was already doing was using the spanish, rename it to pt but if you
> prefer, I can wait for Mark).
It can be done this way, by ranaming an existing one.
If you want an empty one, I can create it but not sooner than at the
evening. If you already started to work, maybe no need to lose what
you have done..
> My idea was to translate a bit until next Monday and send it to Mark.
great
>> I meant Virtaal, sorry, here is the link:
>> http://translate.sourceforge.net/wiki/virtaal/index
> Upsss.. I Thought it was some error. Virtaal. Thanks :) I'm already using
> the po.Edit
po.Edit is ok, and try also to generate a database for translation
memory from 3 existing pt files (set in preferences), so you could
then run the automatic translation - when set Max of missing words and
difference in sentence lenght to zero, you will get all translated
already messages in your wxpy file and then just confirm each.
Cheers,
Milena
>>> 2- If I wanted to use this .po files that I updated in my Windows-
>>> GRASS6.4
>>> wxpython, What do I have to do?
>> You need to create .mo files, what you can easily do with poEdit, just
>> need to set in preferenses creation of .mo file on saving (you don't
>> want me to write the path to it in Polish ;)
>> All the best,
>> Milena
> Thanks Milena
> Best Regards,
> Antonio Rocha
>>> Thanks Milena
>>> Best Regards,
>>> Antonio Rocha
>>> Milena Nowotarska wrote:
>>>> Ola Antonio,
>>>> it is great to hear that you want to contribute in translation process.
>>>> Please follow this wiki page:
>>>> http://grass.osgeo.org/wiki/GRASS_messages_translation
>>>> if you find it unclear, please let us know what information should be
>>>> added.
>>>> You may download the .po files directly from svn source or I can just
>>>> send you the latest files for translation.
>>>> On the wiki also tools for translation are described, but lately we
>>>> discovered a nice virtaal tool, which in my opinion is the fastest and
>>>> most pleasant as for now - on windows platform. It has also a nice
>>>> wizard which will make you familiar with all the tricks and shortcuts
>>>> which will make your work nice and fast. poEdit is also a nice tool,
>>>> but has less pleasant suggestions, and the dictionaries has to be set
>>>> by the user.
>>>> The translated files, as for now, you send directly to Markus.
>>>> If you have any further questions, don't hesitate to ask here, we will
>>>> pleased to help you.
>>>> Best,
>>>> Milena
>>>> 2009/11/11 António Rocha <antonio.rocha at deimos.com.pt>:
>>>>> Greetings all
>>>>> I'm starting to do some effort to translate GRASS from English to
>>>>> Portuguese. Not only GRASS messages but also menus, buttons, etc.
>>>>> What I would like to know, for now, is what translated files and where
>>>>> should I upload them in order to share my work with GRASS community.
>>>>> Also I would like to know if there is any tutorial, tasklist or
>>>>> anything
>>>>> to
>>>>> follow during the translation process.
>>>>> Best regards,
>>>>> Antonio Rocha
>> _________________________________
>>>>> grass-translations mailing list
>>>>> grass-translations at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/grass-translations
>> __________ Information from ESET NOD32 Antivirus, version of virus
>> signature database 4598 (20091112) __________
>> The message was checked by ESET NOD32 Antivirus.
>> http://www.eset.com
> __________ Information from ESET NOD32 Antivirus, version of virus signature
> http://www.eset.com
More information about the grass-translations
