[GRASS-translations] Fwd: Add tab to translated string
Daniel Victoria daniel.victoria at gmail.com
Fri Mar 3 03:14:32 PST 2017
Answer from Transifex support regarding TABs on strings...
---------- Forwarded message ----------
From: Nina Eleftheriadou <support at transifex.com>
Date: Fri, Mar 3, 2017 at 5:49 AM
Subject: Re: Add tab to translated string
To: Daniel Victoria <daniel.victoria at gmail.com>
Hi Daniel,
Thank you for contacting Transifex support and submitting your request.
Regarding your case, you can translate such a string using either the
escape sequence (\t) you mentioned or just copy the source text to the
translation area and start replacing words as follows:
[image: Screen-Shot-2017-03-03-at-10-34-32-AM.png]
I hope it helps.
Please let me know if I can be of any further assistance.
Have a nice day!
Regards,
Nina
Nina Eleftheriadou
Customer Success Engineer | Transifex
How would you rate my reply?
[image: Satisfaction Rating Icons]
{#HS:326809898-27268#}
On Wed, Mar 1, 2017 at 10:15 AM PST, Daniel Victoria <
daniel.victoria at gmail.com> wrote:
> I need to translate a string that has tabs (shown as arrows) in it. How do
> I translate that using the browser interface? Should I add \t?
> Thanks
URL: <http://lists.osgeo.org/pipermail/grass-translations/attachments/20170303/36dd8162/attachment-0001.html>
More information about the grass-translations mailing list
