r.surf.sor
Michael Shapiro
shapiro at zorro.cecer.army.mil
Mon Apr 27 22:10:38 EDT 1992
r.surf.sor was an experiment on my part to see if this kind of
technique could be used to generate surfaces. It is essentially
based on the method as described in Numerical Recipes in C. It
makes the simplifying assumption that the surface satisfies
Lapace's equation:
d^2 f d^2 f
----- + ----- = 0
dx^2 dy^2
A more robust tool would use a more complex function as well as
include stream information. I made it available since the other
surface generating modules were lacking in certain regards.
Current research and development at CERL has lead to the creation
of an improvement on this basic idea. The work was presented at
the GRASS User's Conference. The surface is modeled by a more
complicated formula than the Laplace equation, although the
technique for "solving" the equation is not sor - it is an
analytic solution based on a set of N nearest points.
Hopefully Dave Gerdes will elaborate on the new technique and its
availability.
