p.map
McCauley Technical Services
darrellmy at ids.net
Sat Nov 14 15:04:29 EST 1992
IBH7CAB at MVS.OAC.UCLA.EDU (IBH7CAB at MVS.OAC.UCLA.EDU) writes on 14 Nov 92:
>my note that I was following your instructions in GRASSCLIPPINGS
>6(1):16 . After issuing p.select painter=ppm, I ran p.map with
Hence you used p.ppm.
>which produced the b&w map, but without the legend or bottom frame
>line.
regarding the bottom frame line, do you have any/all updates?
M. Shapiro and I went round and round about this once---there
may have been a change in the code to fix this.
--Darrell
