Problems with ftp on moon.cecer.army.mil
    Kenneth R Brownfield
    brownfld at zorro.cecer.army.mil
    Wed Apr 21 10:52:52 EDT 1993
Andreas Holz said:
|What about the ls command on moon.cecer.army.mil?. Everytime
|I try a ls, I get the message
|	425 Can't build data connection: Interrupted system service.
     This is a very low-level problem that as of yet has not been solved.
The problem exists for network connections that have long delay times (for
instance, US to Europe).  If dir doesn't work, there is a file called ls-lR
in /grass that contains a constantly-updated directory of all the GRASS
archives.  If you "cd /grass" and "get ls-lR" you'll have a file that will
help you navigate through the ftp site without the need of the ls command.
     Hope this helps!
|Dipl. Geol. Andreas Holz    email: asholz at cip.informatik.uni-erlangen.de
|Institut fuer Geologie und Mineralogie
|Schlossgarten 5
|W-8520 Erlangen
|GERMANY
							Ken.
______________________________________________________________________________
Kenneth R. Brownfield                 |         brownfld at amber.cecer.army.mil |
Office of GRASS Integration,          | grass-lists-owner at moon.cecer.army.mil |
United States Army Corps of Engineers |   grass-ftp-admin at moon.cecer.army.mil |
Construction Engineering Research     |                   (800) USA-CERL x526 |
Laboratories, Champaign, Illinois     |                   (217) 373-7222  fax |
