v.patch output (fwd)
    Richard Beecham
    beecham at aerg.canberra.edu.au
    Thu Dec  9 02:35:58 EST 1993
Having had to delete the odd vector file myself - you need to specify that it is
vector, (the default is raster).  Try
                g.remove vect=topo
With the digitizing problem - I can't help.  I have had the odd line not
appear when GRASS and I both know it is there. It came back up when I
redigitized over the top of it.  Have you tried v.digit on the vector file you
copied from?
On Wed, 8 Dec 1993, Lesley-Ann Dupigny wrote:
> Hello
> I am running GRASS 4.0 and created a map of a Caribbean island in v.digit.
> The map was on two sheets, and were therefore joined with v.patch. I then
> ran v.support on the patched output (soils) before copying it with g.copy
> to another file (topo). I then edited the new file (topo) in v.digit with
> the "no digitizer" option. The edited (topo) file could be viewed with
> d.vect, however, when I went back into v.digit this time specifying the
> Calcomp digitizer, no map appeared when the screen was eventually redrawn.
> I then decided to remove the new file (g.remove) but got the following -:
> 	REMOVE [topo}
> 	raster  missing
> 	header  missing
> 	category missing
> 	color   missing
> 	history missing
> 	misc    missing
> A g.list revealed that topo had NOT been removed after all.
> Could someone please show me where I am going wrong?
> Thanks
> Lesley-Ann Dupigny.
