v.patch output (fwd)
Olga Waupotitsch olga at zorro.cecer.army.mil
Thu Dec 9 14:43:15 EST 1993
In info.grass.user you write:
>Hello
>I am running GRASS 4.0 and created a map of a Caribbean island in v.digit.
>The map was on two sheets, and were therefore joined with v.patch. I then
>ran v.support on the patched output (soils) before copying it with g.copy
>to another file (topo). I then edited the new file (topo) in v.digit with
>the "no digitizer" option. The edited (topo) file could be viewed with
>d.vect, however, when I went back into v.digit this time specifying the
>Calcomp digitizer, no map appeared when the screen was eventually redrawn.
>I then decided to remove the new file (g.remove) but got the following -:
>	REMOVE [topo}
>	raster  missing
>	header  missing
>	category missing
>	color   missing
>	history missing
>	misc    missing
>A g.list revealed that topo had NOT been removed after all.
>Could someone please show me where I am going wrong?
>Thanks
>Lesley-Ann Dupigny.
You probably typed g.remove topo (which assumes topo is raster file)
you should type g.remove vect=topo.
BTW: Am I right that you are using grass4.0, and not grass4.1?
Olga
