r.in.sunrast, v.digit
Tom Meixner
tom at hwr.arizona.edu
Thu Jul 8 16:45:34 EDT 1993
James Mulhern writes:
I am trying to input some data into grass, but it is proving very difficult !
I've got an image saved as a sun raster file ( converted from xbm in xv) and
I've tried to convert into a grass raster file using r.in.sunrast but I get the
following error message :
monitor.ras - this rasterfile format not supported
Does anyone one know why this is happening this format should be o.k, I have
even tried doing a sun screendump of the image and then tried to convert that,
but guess what :
I have read in the man pages that scanned raster data can be converted into
GRASS vector file format, if so how is this done {r.in.sunrast probably!}
Also how do you use v.digit without a digitizer?
Can anyone help me ?
James,
I can't help you with the monitor.ras problem.
But as for v.digit, you just need a computer equiped with a mouse
to act as the digitizer arrow. There may be a special hardware or
software setup needed but I do not believe that there is.
thanks,
tom
