r.in.sunrast, v.digit
Brian Culpepper brian at cast.uark.edu
Thu Jul 8 18:12:36 EDT 1993
> Hi !
> I am trying to input some data into grass, but it is proving very difficult !
> I've got an image saved as a sun raster file ( converted from xbm in xv) and
> I've tried to convert into a grass raster file using r.in.sunrast but I get the
> following error message :
>      monitor.ras - this rasterfile format not supported
> Does anyone one know why this is happening this format should be o.k, I have
> even tried doing a sun screendump of the image and then tried to convert that,
> but guess what :
> I have read in the man pages that scanned raster data can be converted into
> GRASS vector file format, if so how is this done {r.in.sunrast probably!}
> Also how do you use v.digit without a digitizer?
> Can anyone help me ?
Are you screendumping an uncompressed image? r.in.sunrast is not happy with
a compressed image.  If your asking how to edit with your mouse, one of my
comrades told me there should be a line,such as the one below in your digcap
file.
none:nodig:nofile:  Run digit without the digitizer.
Hope this helps...
R. Brian Culpepper                                 Research Assistant
Center for Advanced Spatial Technologies           (fax) 501 575-3846
Rm. 214 Ozark Hall                                (work) 501 575-6159
University of Arkansas                            brian at cast.uark.edu
Fayetteville, AR 72701
All opinions are my own and do not necessarily reflect those of the
Center for Advanced Spatial Technologies or the University of Arkansas.
