LT+ on SUN (RAM error)?
Dave Gerdes
dpgerdes at zorro.cecer.army.mil
Mon Jun 7 10:54:49 EDT 1993
LTPlus comes with a default limit of 8M for the size of the raster.
This can be changed by editing your 'config' file and changing the line:
malloc = 8000000
> Sender: <wylie at gpsrv1.gpsr.colostate.edu>
> Date: Wed, 02 Jun 1993 11:30:03 MDT
> From: "Bruce K. Wylie (303) 490 8336" <wylie at gpsrv1.gpsr.colostate.edu>
> Sender: lists-owner at max.cecer.army.mil
> Reply-To: grassu-list at max.cecer.army.mil
> Precedence: Bulk
> Message-Id: <0096D6C1.B9723420.22940 at gpsrv1.gpsr.colostate.edu>
> Subject: LT+ on SUN (RAM error)?
> Using the LTPlus from grass4.1 we get an error saying that we
> do not have enough RAM when we try to import a "ras" file. The
> LTPlus we have on a 386 PC with SCO unix has no problem (8 meg RAM)
> were as the SUN 1+ with 16 megs of RAM runs out of RAM. Have we
> missed something in the installation/compiling/configuration
> process or has the "import ras" command changed with the new
> version of LT+ so that the maximum value can not be set?
> Bruce Wylie
David Gerdes
US Army Construction Engineering Research Lab
Spatial Analysis & Systems Team
d-gerdes at cecer.army.mil
