No subject
Net.Noise owner
news at max.cecer.army.mil
Sun Mar 7 00:24:32 EST 1993
Newsgroups: info.grass.user
Path: zorro.cecer.army.mil!shapiro
From: shapiro at zorro.cecer.army.mil (Michael Shapiro)
Subject: Re: NO carriage/return & line/feed
Message-ID: <C3I70v.9J0 at news.cecer.army.mil>
Sender: news at news.cecer.army.mil (Net.Noise owner)
Organization: US Army Corps of Engineers Construction Engineering Research Labs
References: <Pine.3.05.9302260734.A24664-a100000 at ptolemy.geog.umn.edu>
Date: Sun, 7 Mar 1993 05:24:31 GMT
Lines: 28
In <Pine.3.05.9302260734.A24664-a100000 at ptolemy.geog.umn.edu> harry at atlas.socsci.umn.edu (Kuo-Chen Chang) writes:
>Hopely someone can help me out of this mystry.
>I just installed GRASS4.1BETA under Linux. With some minor modifications,
>the new GRASS is up and running. So far, it is fine except the text display.
>It seems to me that there is no carriage/return and line/feed. The output
>just dump onto screen as a long long single line. But when you are in a
>module, for example, r.buffer, the display is fine.
>The losing of CR/LF continues even after I exit GRASS. Any comment or
>suggestion is warmly welcome. Many thanks!
>--Harry
>ps, I suspect, there's something related to termcap that I have to change.
You don't have to change termcap. It is GRASS/Unix curse at fault. The
workaround may be to type
LINEFEED reset LINEFEED
Michael Shapiro U.S. Army CERL
Environmental Division
