v.digit problem
    Malcolm Williamson
    malcolm at cast.uark.edu
    Tue Apr  5 11:00:33 EDT 1994
> GRASS net--
> We're having a problem with v.digit's display window.  When we enter
> control points, chech registration, and define the digitizing window we
> seem to have a scaling problem in one direction (either the X or Y,
> depending on how we set up the map).  V.digit creates a long skinny
> window whose coordinates do not match the digitizing window we
> entered.  After this point, we can digitize normally, points returned
> from the digitizer have the correct map coordinates, etc., but they
> fall outside the bogus digitizing window on the graphics monitor.
> Please help!  We have run out ideas.
> Michael Camann                          camann at dial.pick.uga.edu
> Department of Entomology                camann at phoenix.cs.uga.edu
> University of Georgia                   (706) 542-1388
> Athens, GA 30602                        (706) 542-2276
Mike,
What projection are you working in? I noticed a similar situation when working
on the state of California in Lamberts Conformal Conic projection. It was
pretty obvious that it was a result of the geographic location in that
particular projection.
One last thought. If you are running GRASS4.1, are you using update 4.1.2 or
newer? 4.1.1 has a bug in v.digit.
Malcolm D. Williamson - Research Assistant       E-mail: malcolm at cast.uark.edu
Center for Advanced Spatial Technologies      Telephone: (501) 575-6159
Ozark Rm. 12                                        Fax: (501) 575-3846
University of Arkansas
Fayetteville, AR 72701
