What is ppm
Bill Brown
brown at zorro.cecer.army.mil
Fri Apr 8 10:40:23 EDT 1994
Here's an excerpt from some documentation that comes with San Diego
Supercomputing Center's imtools, available by ftp from:
ftp.sdsc.edu
IMPPM(3IM) SDSC IMAGE LIBRARY IMPPM(3IM)
NOTES
SDSC image library support of the ppm format does not
require use of the PBM+ libraries and tools. It does not
contain proprietary code or any code from Jef Poskanzer's
original PBM+ suite. ppm format handling is available on
any machine for which the SDSC image library is available.
PBM (Portable Bit Map) started with support for 1-bit mono-
chrome images (see impbm(3IM)). Support was added for 8-bit
grayscale images (see impgm(3IM)), also called PGM (Portable
Grayscale Map), and 24-bit RGB images, also called PPM
(Portable Pixel Map). Each of these defined a new file for-
mat.
The original file formats were ASCII. To reduce the disk
space required to store such files, three additional "raw"
formats were defined. The raw formats stored the same
information as their ASCII counterparts but in binary,
reducing the disk space requirement by around 60%.
Today the PBM+ suite contains six related file formats:
PBM ASCII 1-bit bitmaps
PGM ASCII 8-bit grayscale pixel maps
PPM ASCII 24-bit RGB color pixel maps
RPBM Raw binary 1-bit bitmaps
RPGM Raw binary 8-bit grayscale pixel maps
RPPM Raw binary 24-bit RGB color pixel maps
The original PBM suite included a variety of tools. Some
handled PBM files, but not PGM or PPM. Others handled PGM
files, but not PBM or PPM. Then the newer PBM+ distribution
introduced a set of tools that recognized all six file for-
mats. These tools generically referred to image files as
PNM files, which stands for "Portable aNy Map."
The SDSC image library treats the six PBM+ file formats
separately. This man page only discusses the PPM file for-
mat (ASCII RGB). The remaining file formats are discussed
in their own man pages.
Reading PPM image files
For compatibility with the PBM+ suite, the SDSC image
library can read any of the PBM+ file formats when the ppm
format name is used. PBM+ files are read in and mapped to
VFBs as follows:
File format Depth/color Mapped to VFB
PBM 1-bit monochrome IMVFBMONO without a CLT
PGM 8-bit color index IMVFBINDEX8 without a CLT
PPM 24-bit RGB IMVFBRGB without a CLT
RPBM 1-bit monochrome IMVFBMONO without a CLT
RPGM 8-bit color index IMVFBINDEX8 without a CLT
RPPM 24-bit RGB IMVFBRGB without a CLT
White space, and comments starting with # and extending to
the end of the line are ignored. White space and comments
are not allowed within the raw binary image body.
ppm images are always stored noninterlaced (i.e.,
RGBRGBRGB...). Scanline- and plane-interlaced modes are not
available in ppm files.
ppm files support no compression schemes.
AUTHORS
Dave Nadeau and Don Doering
San Diego Supercomputer Center
CONTACT
SDSC consultants, (619)534-5100, consult at y1.sdsc.edu
