ps.map EPS --> ps: possible?
    Bob Harrington
    bobh at denali.hwr.arizona.edu
    Mon Aug  1 16:45:05 EDT 1994
In article <CtK1K1.1F8D at yuma.ACNS.ColoState.EDU>,
ront at picea.CNR.ColoState.EDU (Ronald Thomas) writes:
>Has anyone yet found a workable solution to get the EPS format of ps.map
>into any graphics package for editing, either by choosing a specific package
>or a converter utility?
I've successfully used the commercial package IslandDraw to annotate ps.map
output.  I read the ps.map generated eps into IslandDraw, annotate
and print directly from IslandDraw on a HP XL300 using postscript.  It all
happens in SunOS though, so if you have to use DOS, this might not be a
solution for you.
I don't know what the package costs.  Perhaps someone from Island Graphics
is reading and can provide info for you, or I can dig up if you need.
Bob Harrington
