loading intergraph design files into grass.
    Allan Axon
    aaxon at ogsun1.dnr.ohio.gov
    Thu Feb  3 09:12:12 EST 1994
We transfer .dgn files into GRASS 4.0 via .dxf format and v.in.dxf
I do not know if GRASS 4.1 has a command to import .dgn files directly without
going through .dxf.  The .dxf files are created by the Intergraph software.
Good luck,
Allan Axon
Ohio Department of Natural Resources |
Division of Geological Survey        |
Mineral Resources and                |      Phone: 614-265-1030
        Geochemistry Section         |      FAX:   614-447-1918
4383 Fountain Square Dr.             |
Columbus, OH  43224-1362             |
Internet:  aaxon at ogsun1.dnr.ohio.gov
> Does anyone know if there is a command to load intergraph design files
> into GRASS (.dgn files).
> I know that other systems such as ARC/INFO have such a command (in
> ARC/INFO it is IGDSARC).
> If anyone knows of such a command and can help it would be greatly
> appreciated.  Thanks,
> Paul Sorensen, Dept. of Geography, UCSB
> (paul at geog.ucsb.edu)
