"Automatic" Zoom
Lars Schylberg larss at fmi.kth.se
Fri Feb 4 02:50:17 EST 1994
> Hi people,
> I need a function, a tool or something else, that allows me to restrict
> a region only where there are significant data (i.e. not zero!), without
> use d.zoom utility or interactive tools.
> Thank you in advance for any suggestion.
> -- FRY.
I wrote a little script a couple years ago, that zooms in around specified
categories.  Maybe you can get some ideas from this script. In my case the
significant data is the categories that I specify.
Lars
Lars Schylberg                       Email: lasc at celsiustech.se
CelsiusTech Systems AB                  or: larss at fmi.kth.se
S-175 88 Jarfalla                    Tel.   +46 8 580 847 03
Sweden                               Fax.   +46 8 580 872 59
r.zoom_cats.sh
#!/bin/sh
#  r.zoom_cats.sh
#  Zoom the region setting so that the region have one or a specified
#  number of cells free around the max and min coordinates of one or
#  several categories.
#  It's useful for zooming in on one category or many category areas
#  that has been creted with the r.clump program for local processing
#  of that area.
#  Author: Lars Schylberg
#  email: larss at fmi.kth.se
#  Date: 920304
# Check if GRASS is running
test "$GISRC" || echo "GRASS is not running" || exit 2
#  Evaluate arguments
if [ $# != 4 ]
then
    echo
    echo Usage: `basename $0`
    echo '       input=mapname '
    echo '       cats=cat[,cat,cat] '
    echo '       border=cells '
    echo '       visual=yes|no'
    echo
    echo '  This program zooms the region around the max and min'
    echo '  coordinates of one or several category values '
    echo
    exit 1
fi
#				 Parse input arguments
for i do
	case $i in
		input=*)
			IN=`echo $i | sed s/input=//` ;;
		in=*)
			IN=`echo $i | sed s/in=//` ;;
		i=*)
			IN=`echo $i | sed s/i=//` ;;
		cats=*)
			CATS=`echo $i | sed s/cats=//` ;;
		c=*)
			CATS=`echo $i | sed s/c=//` ;;
		border=*)
			BORDER=`echo $i | sed s/border=//` ;;
		b=*)
			BORDER=`echo $i | sed s/b=//` ;;
		visual=*)
			VIS=`echo $i | sed s/visual=//` ;;
		vis=*)
			VIS=`echo $i | sed s/vis=//` ;;
		v=*)
			VIS=`echo $i | sed s/v=//` ;;
			echo ""
			echo "Unrecognized option: $i"
			echo 'Options: input=mapname '
                        echo '         visual=yes|no '
			exit 1
	esac
done
#				 Check the input arguments
eval `g.findfile element=cell file=$IN`
if [ ! "$file" ]
then
    echo "$IN - cell file not found"
    exit 2
fi
TMP=/tmp/.`basename $0`.$$
DUMMY=/tmp/dummy.$$
RCRULE=/tmp/rcrule.`basename $0`.$$
if test -f $RCRULE
then
   /bin/rm $RCRULE
fi
touch $RCRULE
for i in `echo $CATS | awk -F, '{ for (i=1; i<=NF; i++) print $i }'`
do
   echo $i' = 1' >> $RCRULE
done
cat $RCRULE | r.reclass input=$IN output=OBJ.cell
/bin/rm $RCRULE
#				 Get the categories max and min coordinates
g.region rast=OBJ.cell zoom=OBJ.cell
g.region -p | sed "s/\..*//" > $TMP
g.remove rast=OBJ.cell >> $DUMMY
N=`grep north $TMP | sed "s/[^0-9]*//"`
S=`grep south $TMP | sed "s/[^0-9]*//"`
E=`grep east $TMP | sed "s/[^0-9]*//"`
W=`grep west $TMP | sed "s/[^0-9]*//"`
/bin/rm $TMP
#				 Determine current resolution to place
#				 a n pixel border around the categories
NSRES=`grep nsres $TMP | sed "s/[^0-9]*//"`
EWRES=`grep ewres $TMP | sed "s/[^0-9]*//"`
/bin/rm $TMP
NSBORDER=`expr $NSRES \* $BORDER`
EWBORDER=`expr $EWRES \* $BORDER`
north=`expr $N + $NSBORDER`
south=`expr $S - $NSBORDER`
east=`expr $E + $EWBORDER`
west=`expr $W - $EWBORDER`
#				 Check that the new region not is
#                                outside the default region
g.region -dp | sed "s/\..*//" > $TMP
DN=`grep north $TMP | sed "s/[^0-9]*//"`
DS=`grep south $TMP | sed "s/[^0-9]*//"`
DE=`grep east $TMP | sed "s/[^0-9]*//"`
DW=`grep west $TMP | sed "s/[^0-9]*//"`
/bin/rm $TMP
if [ $north -gt $DN ]; then
north=$DN
fi
if [ $south -lt $DS ]; then
south=$DS
fi
if [ $east -gt $DE ]; then
east=$DE
fi
if [ $west -lt $DW ]; then
west=$DW
fi
#				 Set the new region
g.region n=$north s=$south e=$east w=$west nsres=$NSRES ewres=$EWRES
if [ $VIS = yes ] ; then
  d.erase
  d.rast $IN
fi
#				Clean up
/bin/rm $DUMMY
