Xgrass dumps core
Randy Hills
rhills at snow.nohrsc.nws.gov
Fri Feb 25 14:04:25 EST 1994
> Hello
> Sometime ago I had problems with Xgrass compilation which was solved.
> This time (!) I have problems to run it!!! The initial menu appears,
> I choose the data-base, the location, the mapset and when I want to
> add items, such as the session name, I can't write anything in the
> appropriate field. After a while, I get "Illegal instruction (core dumped)".
A while ago I had a similar problem, and by replacing
char retBuf[256];
with
static char retBuf[256];
in the file xc.name.c, and recompiling, the problem disappeared.
Randy Hills, National Operational Hydrologic Remote Sensing Center
Minneapolis, Minnesota
