X-windows/Linux
David Gerdes
dpgerdes at zorro.cecer.army.mil
Fri Jan 7 17:16:40 EST 1994
In article <8DE1CB4CE1 at hal2010.nw.uoguelph.ca> you write:
>Hello everyone,
>This problem looks rather strange to me. I have successfully
>installed and configured X-windows in Linux. However, anytime I
>invoke "startx", I get six fine blue screens with a window at the
>left top corner of each. Everything works fine except that when I
>invoke any operation, I get similar response in the
>other five screens. For example, if I display a raster map,
>calculator etc.. I get a similar display in the other five screens. I
>don't know if that is the way the windows on Linux works but I
>strongly suspect something is going wrong. My only problem now is how
>to get rid of the other five screens; otherwise everything seems to
>be working fine. Any help on this will be much appreciated. Thanks in
>advance.
>eugene
> e-mail: agyei at net2.eos.uoguelph.ca
I have never worked w/ Linux, but what you are describing sounds
like using the wrong SuperVGA driver. I would check the brand
and model of your VGA card and make sure you are configuring Linux
appropriately.
David Gerdes
US Army Construction Engineering Research Lab
Spatial Analysis & Systems Team
