HP XL300 driver
David Houlder
david at dart.anu.edu.au
Wed Jun 1 11:42:15 EDT 1994
> I've been trying to get the driver in src.contrib/OTHER/HPXL300 to work
> with our department's XL300 printer. The code compiles fine and p.map
> sends to the printer OK, but it is not received correctly. I have the
> postscript option, but it is disabled by setting the dip switches on the
> back for PCL5. Is this correct? Any other tips? All I get are error
> messages.
> Bill Baker
> bakerwl at uwyo.edu
Firstly, what happens if send a pcl file to the printer manually? Do you get anything useful?
I use it and it seems fine (SunOS 4.1.3, sparc IPX and sparc 1). We have a non-standard setup that uses the lpd daemon and such, and it goes a bit like this...
1) Instead of calling p.map, we run this script...
#! /bin/sh
# wrapper for p.map
# send file to pj printer on dart
: ${LOCATION:?"not set. Run this from grass, or 'Grass shell' under Xgrass"}
tempfile=/tmp/`hostname`.`basename $0`.$$
mknod $tempfile p
MAPLP=$tempfile
export MAPLP
# Now start up lpr, with input coming from the pipe we just created
# The beauty of this approach is that the process writing to
# the pipe can background itself, and the lpr process will hang around
# until its complete, then delete the temporary pipe.
(echo lpr started > /dev/tty; lpr -Pgeogpj < $tempfile ; rm $tempfile ; echo lpr done > /dev/tty) &
p.map $*
2) the printcap entry for geogpj on the host grass is running looks like this
20|geogpj|Geography PaintJet Printer:\
:lp=:\
:mx#0:\
:sd=/usr/spool/lpd/geogpj:\
:rm=dart:\
:rp=pj:
3) the printcap entry on the printer host looks like this...
pj|HP PaintJet in native mode:\
:mx#0:sf:sh:\
:lp=/dev/bpp0:\
:sd=/disk2/var/spool/lpd/paintjet:\
:lf=/disk2/var/spool/lpd/paintjet/log:
Hope this helps
David Houlder Phone: +61 6 249 4613
Geography Department (In Aust.: (06) 249 4613)
The Australian National University Fax: +61 6 249 3770
------------ "668: The neighbour of the beast" ---------------
