Problem with printing ps.map output
kang at risca.rs.msu.edu
Wed Jun 1 12:29:02 EDT 1994
Hi all,
I have been using ps.map to generate PS outputs very successfully. However, I
do have a problem right now. Here is my backgroud information:
Computer IBM RISC/6000
GRASS 4.1.3
Printer HP LaserJet IIISi
Maps I used r.contour to generate several contour vector maps with
different contour intervals (say 5, 10, and 15 units)
PS files I used ps.map to create PS files, only one contour map was used
each time. The ps.map always gave me a successful message.
Printing I, then, ftp those PS files to a PC with HP laserJet IIISi
printer, and simply copy the PS files to the printer port.
Problem Only the PS file with 10 units contour interval can be printed
and the 5 and 15 units PS files failed. The printer printed
an error message as below:
ERROR: limitcheck
OFFENDING COMMEND: rlineto
The problem apprantly is not caused by the density of the contour lines. Can
anyone help me solve the mystery? Thanks in advance.
Yung-Tsung Kang
Center For Remote Sensing, Michigan State University
E-Mail: kang at risca.rs.msu.edu
