Default monitor size [Linux]
Craig Neidig
neidig at vinny.cecer.army.mil
Tue Jun 7 09:53:30 EDT 1994
I believe for this particular situation using the command:
"d.frame -e "
is more appropriate than d.erase
craig neidig
usacerl
technical assistance center
> From grass-lists-owner at max.cecer.army.mil Tue Jun 7 02:39:00 1994
> From: schmidt at ipf.bau-verm.uni-karlsruhe.de (Andreas Schmidt)
> Subject: Re: Default monitor size [Linux]
> According to Ken Sibley:
> > > After resize the screen, you must always type "d.erase" (only with LINUX)!
> > NOT TRUE. You should always use d.erase after resizing the monitor in
> > X. GRASS does not know when the monitor has been resized therefore you
> > must tell it; using d.erase does this.
> > Ken Sibley
> > USDA-SCS "Hell, if you understand everything I say,
> > ksibley at ncg.scs.ag.gov you'd be me!" - Miles Davis
> But with SunOS 4.x.x it works without "d.erase", with LINUX not.
> Andreas
> A Happy GRASS USER!!!
> Andreas Schmidt, IPF-Universitaet Karlsruhe, Englerstr. 7, D-76128 Karlsruhe
> Telefon: +49 721 608 3676 Fax: +49 721 694568
> Internet: schmidt at ipf.bau-verm.uni-karlsruhe.de
