v.proj,v.support
George Taylor oregon at chaos.ATS.ORST.EDU
Tue Jun 21 19:49:17 EDT 1994
Hello all,
I am having difficulties in reprojecting vectors (from lat/lon to albers).
Could someone please advise me as to what might be causing the problem?
Here are the steps :
v.proj
v.support
The projection appears to run without any errors.  When I run v.support,
I get the following error messages :
GRASS 4.11 >> v.support r_10
   V.SUPPORT:
Selected information from vector header
 Organization:
 Map Name:      from raster map rcomb
 Source Date:
 Orig. Scale:   100000
 No snapping will be done
    Reading Vector file.
 100%
    Building areas
    Building islands
    Attaching labels
Bad line 'LAB2÷¹|äÁ     XÿÁB/½ -1771529.3476489484 2385391.4491144288      10
Bad line 'LAB%  ï3]Á;PýÁB/½ -1789979.6952772755 2378259.8678039745      10
Bad line 'LAB"¡»ÜÒÁ;a¥  ùÌÁB/½ -1794469.0389678814 2377027.4676674390      10
Bad line 'LAA¨aÝÁ<_ ߢÏÁB/½ -1859360.1245061641 2314434.0391399697      10
WARNING: line 1 label: 10 matched another label: 10.
 Number of lines:   30
 Number of nodes:   30
 Number of areas:   0
 Number of isles:   0
 Number of atts :   26
 Number of unattached atts :   0
 Snapped lines  :   0
Mapset <or> in Location <us_albers>
When v.support is executed on other non-projected vector files, there appear
to be no errors (so far).  As far as I can tell, the errors appear only
after reprojecting.  I suspect v.proj.
GRASS was compiled from scratch and we are at update package 4.  We also
downloaded the file "mapgen.tar.Z", created a src.related directory, and
compiled mapgen and proj.
I noticed there is a v.proj directory in src.alpha/mapdev.  There is also
v.proj in the src.contrib/SCS/vector directory as well.  Could there
be a conflict here in the compilations? Or perhaps there is
some type of conflict between the v.proj and mapgen/proj compilations.
(I have been following the discussion about SCS proj and USGS proj)
Thanks in advance,
Wayne Gibson
Oregon State University
