r.stats
Brian Culpepper
brian at cast.uark.edu
Wed Mar 30 11:45:08 EST 1994
Mark Gregory writes:
> I am trying to use r.stats to generate area statistices which I wish to pass
> into another application. I can generate the data in the proper format with
> the command
> r.stats -a input=x output=y
##but my statistics are always in meters. The manual says that 'Area statistics
##can be given in units of acres, hectares, square miles and cell counts.'
##What is the option to output the statistics in acres?
Mark,
I believe r.stats only deals with square meters or cell counts.
According to our on-line manual:
DESCRIPTION
r.stats calculates the area present in each of the
categories of user-selected raster map layer(s). Area
statistics are given in units of square meters and/or cell
counts......<stuff deleted>
So I think awk, as you mentioned in your original posting, may be the way
to go, but I'm sure there are other methods of determining acreage. It could
be done with r.mapcalc........plus others.
Have a Great Day,
R. Brian Culpepper Research Assistant
Center for Advanced Spatial Technologies (fax) 501 575-3846
Rm. 214 Ozark Hall (work) 501 575-6159
University of Arkansas brian at cast.uark.edu
Fayetteville, AR 72701
All opinions are my own and do not necessarily reflect those of the
Center for Advanced Spatial Technologies or the University of Arkansas.
