GRASS 4.1 on Solaris 2.x
Nair Venugopal
venu at utkux.utcc.utk.edu
Mon Oct 3 14:25:32 EDT 1994
I installed the Grass4.1 binaries for Solaris 2.3 on our SPARCserver 690.
One of my users says that it does not work correctly.
> After creating and defining my LOCATION region, GRASS asks :
> "{ Do you accept this region? (y/n) }" for which my answer is y
> GRASS hangs here!!!! The next question should have asked for
> projection.
> If I hit the return key, I get the following message:
> "{ LOCATION <matthew1> created
> But the Projection information files were not created!
> You must run g.setproj successfully before projection software will
> work. }"
I would be grateful if you could help me out.
Thanks
Venu
(venu at utk.edu)
