converting .SIT grass vector files
carson!burla at cerl.cecer.army.mil carson!burla at cerl.cecer.army.mil
Fri Feb 10 11:42:08 EST 1995
Kevin,
The problem is with the software.  Files with extension .SIT are GIS site files.
When you select output option for GRASS vector format, output is actually a
site file.  To over come this problem, select the option below GRASS vector
format (i.e., Gridpoint EPPl7). This will give you an output file with extension.VEC, a vector file.  Seems unbelieveable that commercial software costing
as much as it does would have such a major bug, but it does.  I am not sure if
this problem has been fixed in subsequent releases.  Hope this solves your
problem.
Your welcome,
Burla Martin
GIS Specialist
Ft. Carson, CO
