fast mapcalc
BARNES DAVID
barnesd at lab.cc.wmich.edu
Mon Jul 3 08:00:00 EDT 1995
David Wheatley sez:
<This is rubbish: exactly the kind of half-witted mis-information which gives
<newsgroups a bad name.
Mr Wheatley,
I know that it is almost "that" black day in the lives of all Brits, bu
t
cheer up. There are a lot of newbees out here who have a lot to learn.
Learning enough about complex computer systems to do one's work is a real
challenge, usually a pleasant and rewarding one. Please, make the learning
experience positive.
* My Address *
* DAVE BARNES *
* Geology Dept. *
* Western Michigan University *
* Kalamazoo, MI 49008 *
* email address *
* barnesd at lab.cc.wmich.edu *
On Mon, 3 Jul 1995, David Wheatley wrote:
> >>Most Unix workstations allow you to define a ram-disk. If you have enough
> >>RAM you can copy your location to the ram-disk and then run grass normally.
> >>Jim Hinthorne Voice: 509-963-2826
> >Ram-disk? ... Unix?
> >I'm sorry. I've only been playing on Unix since about 1983, a short
> >timer, and *do not* claim to be a guru, but I have never heard of
> >such a thing as "ram-disk" mentioned in the same breath as Unix.
> >I know there are a few new things out there, but this one does not
> >make any sense to me. Unix does a lot of things with available ram
> >and stacks up a lot of disk I/O in memory, but ... .
> >Did we mistype DOS?
> Some (if not all) unices DO in fact allow 'ram-disks' or whatever you want to
> call it. Slakware LINUX, for example, relies on this feature in order to inst
all
> itself. In case any true unix anoraks want to know how to do it, you mount
> it like any other disk with an entry in /etc/fstab something like this:
> # device directory type options freq pass
> /dev/ramdisk /ramdisk ext2 defaults
> to find out if your flavour of UNIX can do this, check to see if the device
> driver /dev/ramdisk (or something like it) exists. If it does then you can.
> Of course you DO need to be root in order to mount a partition, so this
> might not be the correct solution to the original question ...
> David Wheatley
> Department of Archaeology
> University of Southampton
> Southampton
> SO17 1BJ
