ps.map - changing background color
    Rick Thompson
    rick at cast.uark.edu
    Tue Oct 24 08:00:00 EDT 1995
Hi Thomas,
  ps.map provides that you can do the following:
rast satimage
setcolor 0 white
Check the manual entry section "setcolor". Rick
On Mon, 23 Oct 1995, Tom Hawkins wrote:
> I am trying to create a postscript file, using a region that is larger that
> the raster map I want to plot.  The raster map is a satellite image (created
> using i.composite.  I want to have a white background above (and around) the
> image so I can have text above the image (not in the image).  The ps I do
> create with this image always has a black background, so I have to create
> white text so it will show.
> Is there something I can easily do in ps.map to have the background white?
> The only other way I can think of is to set the region to the size I want,
> then run r.resample, and use the resampled image in ps.map?  Surely there
> must be a better way.
> Thomas E. Hawkins
> California Department of Water Resources - Sacramento
> hawkins at water.ca.gov   (916) 653-5573   Fax (916) 653-2698
