v.support
kang at risca.rs.msu.edu
Tue Sep 26 08:00:00 EDT 1995
Is anyone running GRASS 4.15 on Sun Solaris 2.3? I have problems with the
v.support command. I compiled GRASS4.15 with Sunpro C a few months ago. The
v.support never work for me. It always gave me the Segementation fault. I
also have GRASS4.15 compiled on Linux with gcc 2.6.3 and it failed too. The
error message from Linux is as below:
Converting myfile from 3.0 to 4.0
File is already in 4.0 format
ERROR: File conversion failed. Possibly Disk Full.
ERROR(v.support): Could not build vector file: 'myfile'
I remembered that v.support was working on both platforms with GRASS4.14 or old
er. Then, I moved my vector file to a SUN OS 4.1.3 machine with SCS GRASS 4.12
The v.support worked perfectly. Finally, I ran v.support on a IBM AIX 3.2
with GRASS 4.15. It also failed with Meory fault problem. I probably should
also try the GRASS4.15 static binary but I gave up.
Does anyone have similar experience with a newly compiled GRASS 4.15 (not from
update patches) on Solaris, AIX, or Linux? The only place that I may did
wrong probably is in the compilation setup process where it asked for something
about portable vector 3.0 to 4.0, but I don't really think that I made the
mistake on all the three different platforms. Any help or suggestions are
welcome!
Kang,
