v.support Segmentation fault in solaris 2.5
Mark Gibb
gibb at hubers.cecer.army.mil
Tue Apr 30 08:00:00 EDT 1996
Eric-
I would check the code for the v.build command. There are lines in the
Gmakefile for:
# use -DRAM_OFF if you do not want the digit file loaded into memory
# for optimization, this is also toggle-able from the command line if -
DRAM_ON is used
#EXTRA_CFLAGS = -I../lib -I../libes -DRAM_ON
EXTRA_CFLAGS = $(VECT_INCLUDE) -DRAM_OFF
There are also a couple of lines in the "support.c" file for the v.support
command that you may want to examine also.
mark gibb
unix sys. admin. group
tr-s usacerl
