Graphichs Monitor Problem
Henning Brockfeld
Henning.Brockfeld at wigeo.bwl.uni-muenchen.de
Mon Dec 30 05:54:19 EST 1996
Lawrence Houston wrote:
> The "standard" GRASS 4.1 XDRIVER ONLY works with X-Servers running in
> 8-bit (256 Colour Mode). The above probably indicating that you are
> running your Red Hat 4.0 Server in a 15/16 or 24 bit Colour Mode? Moving
> back to the 8-bit mode should get GRASS's XDRIVER working for you!
The question is: Is there a patched version of XDRIVER which supports
15/16 bit colour mode? This seems to become a FAQ in Linux environments.
Henning
Henning Brockfeld mailto: Brockfeld at wigeo.bwl.uni-muenchen.de
Institut f"ur Wirtschaftsgeographie Universit"at M"unchen
http://www.wigeo.bwl.uni-muenchen.de/~hbrock/
