Can't run d.mon
    Pat Luther
    pluther at usit.net
    Mon Oct 21 08:00:00 EDT 1996
Luc:
I can guarantee this is a XF86CONFIG problem, as I had the same trouble
in setting up my GRASS on Linux.  You need to reconfigure the XF86, with
attention to the video card parameters, specifically the modes for the
video card.
You do not need to compile GRASS-
Let me know if you need additional assistance.  I offer GRASS support & will
send you info on it-
Good luck -
Pat Luther
t 12:51 PM 10/21/96 EDT, you wrote:
>Hello GRASS-users,
>I look forward to the time that I can answer questions but for now I
>still only ask them. I reinstalled GRASS on a Linux 2.0.0 PC with a
>new videocard (Diamond Stealth 64 2MB) after my harddrive had broken
>down and was replaced. GRASS worked under the old configuration with the
>only differencethat it ran on the old harddrive and a Diamond Speedstar
>1MB card. Obviously I had to reconfigure my windows configuration file:
>XF86Config, a Linux file.
>I installed the 1996 Linux compiled linuxg.a* files with the install.sh.
>The problem:
>I can start GRASS just fine and after filling out the entry screen I get
>the GRASS prompt. Running e.g. d.rast works fine until it complains (of
>course) that I need to run d.mon.
>When I run d.mon this is what happens:
>GRASS-GRID > d.mon start=x3
>X Error of failed request:  BadMatch (invalid parameter attributes)
>  Major opcode of failed request:  78 (X_CreateColormap)
>  Serial number of failed request:  75
>  Current serial number in output stream:  76
>Please start graphics monitor <x3>.
>Error - Graphics monitor <x3> not running!
>Problem selecting x3. Will try once more
>I tried:
>- csh and bash (the latter worked before hardrive brake down)
>- fvwm95 and fvwm (the latter worked before hardrive brake down)
>- to install Grass4.1.3 which for some reason did not work, I guess it
>  was confused with the other GRASS4.1.5 still being present.
>A suggestion here at computer services was that I might want to recompile
>GRASS on my own machine. Is that a solution? What does it entail? Where is
>thes source code located of GRASS 4.1.5? (I think i did see 4.1.3)?
>ORRR... is this not a GRASS problem but an X-windows or Linux problem?
>I hope All this info is enough for one of you to help me out. Thanks in
>advance.
>Luc
Pat Scarbrough Luther
AEgis Services Corporation
P.O. Box 160                    "Set your course by the stars
Clinton, TN 37717               and not by the lights of
Phone   423.457.8242            every passing ship."
FAX     423.457.8620
Internet pluther at usit.net               Omar Bradley
