v.support of GRASS4.1
Tom Charnock
charnotw at helios.aston.ac.uk
Tue Sep 3 05:01:17 EDT 1996
> Iwao
> On Sep 2, 5:28pm, Iwao NODA wrote:
> > But my Grass4.1.5 is 'GRASS 4.1 Dynamic Binary Release Update 5' downloaded
> > from
> > ftp://129.229.103.1/pub/grass/grass4.1/release/binary/sun4/ .
> > Is the Update5 not fixed the v.support problem ?
> >-- End of excerpt from Iwao NODA
> I did a bit of checking and the sun4 binary release (update 5) was last
> modified in March 1995, while the fix posted in the GRASS FAQ that I referred
> to was posted in April 1996. This suggests that the v.support error was
> discovered after the update 5 release.
> Perhaps if the person who originally posted the sun4 binary is still a member
> of this list, he or she could recompile the binary with the fix for the
> v.support problem. Otherwise, I think your only choice would be to download the
> source code for GRASS4.1 update 5, and download the fixed file from the FAQ
> (since the source code also contains the bug) and then try to compile GRASS.
> Maybe someone else has a better solution to fixing the v.support program in the
> binaries, like using a patch of some kind.
> Sorry I can't be much help with the binaries since I compiled the source code
> instead of using the binaries.
> Sincerely,
> Jazzman (a.k.a. Justin Hickey)
I found it was possible to get round the v.support error by placing
an empty file of the same name as the vector you are trying to
add topology to in, I think, the dig_plus directory. Not
satisfactory but it worked for me 8-)
cheers Tom
Tom Charnock O--O
Dept Civil Engineering (~~~~)
Aston University ( __ )
Birmingham B4 7ET UK /|\ /|\
charnotw at sun.aston.ac.uk
