XDRIVER24 (was: Calcomp Drawing Board III)
atlas.il.nrcs.usda.gov!gomlra3!ohler
Thu Feb 27 08:58:00 EST 1997
Steve --
I went through this just recently. As Angus suggested, you
can use the XDRIVER24 for 24 bit graphics; however that will
not allow you to switch to float colormode. A second solution
is to switch X from default of 24 to 8 bit mode when starting
the window manager. I am using openwin, so my .login file uses
the following line to start openwin:
/usr/openwin/bin/openwin -dev /dev/fb defdepth 8
Other applications (notably GRASSLAND) may also malfunction
under 24 bit graphics and benefit from the switch to 8bit.
Note that if you are also using Arc/Info the documentation
says it requires 24 bit graphics on sol2.5.
Eric Ohler
USDA-NRCS
>Also we are unable to start a Grass monitor from an Xserver which is
>running CDE as the window manager. If I issue the following command
>once grass has started: d.mon start=gisx1 I get the following error:
>X Error of failed request: BadMatch (invalid parameter attributes)
> Major opcode of failed request: 78 (X_CreateColormap)
> Serial number of failed request: 267
> Current serial number in output stream: 268
>Our monitorcap file has entries like this:
> gisx1:driver/XDRIVER:X-term display (gisx1): \
> /opt/grasstest/dev/fifo.1a /opt/grasstest/dev/fifo.1b \
> ::any terminal
>and these work fine for Xterminals but not Xservers.
>Any comments would be appreciated.
>Steve Moore - Software Coordinator
> Miami University, Oxford, Ohio
> (513) 529-1452
