Compile problem
Malcolm Williamson malcolm at cast.uark.edu
Mon Mar 24 22:43:09 EST 1997
Try removing /usr/ucblib from your LD_LIBRARY_PATH. It caused me a lot of
grief at one time!
	-Malcolm Williamson
On Mon, 24 Mar 1997,
Peizhong Wu wrote:
> Hi, When I try to run GISGEN.head,
> There is following error message:
> /yin5/wupz/grass/src/display/d.3d
>   make -f OBJ/make.rules
> cc -s -o /yin5/wupz/grass/etc/bin/main/inter/d.3d OBJ/main.o OBJ/threed.o
> OBJ/transform.o OBJ/clip.o  OBJ/get_range.o OBJ/check_opt.o
> OBJ/get_inputs.o OBJ/sigint.o OBJ/get_row.o OBJ/draw_face.o
> /yin5/wupz/grass/src/libes/LIB/libD.a
> /yin5/wupz/grass/src/libes/LIB/libdisplay.a
> /yin5/wupz/grass/src/libes/LIB/libraster.a
> /yin5/wupz/grass/src/libes/LIB/libgis.a
> /yin5/wupz/grass/src/libes/LIB/libvask.a -lcurses -ltermlib -lm
> ld: fatal: symbol `Def_term' is multiply defined:
>         (file /usr/ucblib/libcurses.a(curses.o) and file
> /usr/ccs/lib/libtermlib.a(setupterm.o));
> ld: warning: symbol `ttytype' has differing sizes:
>         (file /usr/ucblib/libcurses.a(curses.o) value=0x32; file
> /usr/ccs/lib/libtermlib.a(setupterm.o) value=0x400);
>         /usr/ccs/lib/libtermlib.a(setupterm.o) definition taken
> ld: fatal: File processing errors.  No output written to
> *** Error code 1
> make: Fatal error: Command failed for target
> `/yin5/wupz/grass/etc/bin/main/inter/d.3d'
> GISGEN failure at STEP: src/display/d.3d
> Would some people tell me why?
> Thanks very much
> Peizhong Wu
> University of Michigan
> Ann Arbor, MI 48105
