Creating MASK from vect
Malcolm Williamson malcolm at cast.uark.edu
Mon May 4 12:17:55 EDT 1998
Hi, Stephan
What you must do is create a vector polygon, from which you can create a
raster mask. The way that I would do this is first to create a vector
polygon for your region:
r.mapcalc 'region_poly=1'
r.poly i=region_poly o=region_poly
v.support region_poly
Next, patch this polygon to your shoreline, and create nodes where the
lines cross:
v.patch i=region_poly,(your shoreline layer) o=newmap
v.support newmap
v.spag newmap
v.support newmap
Finally, use v.digit to edit newmap. You must make sure that the lines
surrounding the area that you want to show through your mask are "typed"
as Area (under Edit there is a "re-Type" command), and you must label the
area with a non-zero value, such as 1.
v.support newmap (one more time!)
v.to.rast i=newmap o=ocean_mask
Use r.mask to incorporate "ocean_mask" as your mask when desired.
Remember, the non-zero categories in a raster mask are the areas where
analysis will occur. I know this all sounds complicated, but it's really
fairly simple once you understand how it all works. Good luck,
Malcolm D. Williamson - GIS Specialist         E-mail: malcolm at cast.uark.edu
Center for Advanced Spatial Technologies        Phone: (501) 575-6159
Ozark Rm. 12                                      Fax: (501) 575-5218
University of Arkansas
Fayetteville, AR 72701                            Web: http://www.cast.uark.edu
On Sun, 3 May 1998, Stephan Eickschen wrote:
> Hi GRASSers,
> I would like to create a MASK using a shoreline which I have as a
> vector file (ascii or binary) imported to GRASS. Using v.to.rast
> results is a raster layer where everything is 0 but the shoreline,
> so either everything but the shoreline would be visible or the
> other way round :-( What I would like to have is: a mask, which
> blanks the sea. Since it is not an island, or a lake, it is not a
> closed line, the coastline "enters" at the left (western) end of
> my loacation and "leaves" at the right (easter) end. A simple
> "is-north-of-decision" will fail.
> How can I define an area (comparable like a floodfill - pattern in
> image-processing tools), so that I can build up my mask?
> Or is there a way to make it more directly from the vectors?
> Thanks in advance for any suggestion!
> Regards,
>         Stephan
> Stephan Eickschen                     Tel. : +49 (0)251 83-34704
> Westfaelische Wilhelms-Universitaet   Fax. : +49 (0)251 83-36100
> Institute for Geophysics
> Research Unit of Physical Glaciology  email: eicksch at uni-muenster.de
> Corrensstrasse 24
> 48149 Muenster
> Germany
